Which sway bars do you recommend?
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Im trying to decide on some sway bars for my S13. What would you guys get? Im torn between the Whiteline and the Tanabe Sustec. I included the Largus and the Cusco for you ballers, but seriously, which ones and how come? If i left any out post em up as well as links where to buy.
240DRFT
whitelines are adjustable, and tanabe arent. just something to think about.
EazyBreazy
get the whitelines, i wish i would have if for no other reason than they are adjustable and come with new end links IIRC
nismofly
Car: 89 Nissan 240SX Hatch
my personal vote goes to progress, but you didnt even put those on your list
naed240sx
Car: .....
Non-adjustable aftermarket swaybars are pretty pointless. Adjustability is the key to a tuning your suspension to fit your needs/goals.
JNM240
240DRFT wrote:whitelines are adjustable, and tanabe arent. just something to think about.
How are they adjustable? I mean, what part? The endlinks? SPL sells the adjustable end links seperately (and are currently backordered), so i dont really see/understand what part of a bar would be adjustable.
sdwyzs14 wrote:get the whitelines, i wish i would have if for no other reason than they are adjustable and come with new end links IIRC
That is true, i forgot to look and see which bars come with the new endlinks. And really, that is about 90% of why i am wanting new sway bars, my driver side endlink is toast.
nismofly wrote:my personal vote goes to progress, but you didnt even put those on your list
Post up a link where i can research/price/possibly buy them. I know nada.
There is also Speed Tech (or st), not to be confused with Suspension Techniques (ST). st are the christmas green ones, and ST are the silver ones.
240DRFT
http://www.pdm-racing.com/prod....html
look at the pics, see there are different holes to mount the endlink
EazyBreazy
JNM240 wrote:How are they adjustable? I mean, what part? The endlinks? SPL sells the adjustable end links seperately (and are currently backordered), so i dont really see/understand what part of a bar would be adjustable.
splparts.com click on whichever year you have, then click on suspension, then click on stabalizer bars, then look at the pretty pictures man.....
94_240sx
Car: 94_240SX
This is a good thread. I did some research and it looked like Whiteline was the best. Good to confirm that. This will be my next upgrade...
JNM240
ok, i see now. gotcha!
94_240sx wrote:This is a good thread. I did some research and it looked like Whiteline was the best. Good to confirm that. This will be my next upgrade...
Something else, what about hollow bars vs solid steel bars? The Largus are hollow, and Whiteline are solid. I read that hollow bars only give up 5% of their stiffness over solid bars at a reduction of like 50% in weight. Now im not that concearned about weight, more about overall value and performance.
Really tho, so far it looks like Whiteline: large diameter (especially in rear), new endlinks, adjustable.
Does ANYONE have any comments about others? What about those progress bars? Any information on those?
240DRFT
JNM240 wrote:Something else, what about hollow bars vs solid steel bars? The Largus are hollow, and Whiteline are solid. I read that hollow bars only give up 5% of their stiffness over solid bars at a reduction of like 50% in weight. Now im not that concearned about weight, more about overall value and performance.
thats why nismofly suggested progress sways. theyre the same size of whitelines and adjustable, but are hollow. theyre about $45 more for each bar and can be found at sportcompactonly.com
nismofly
exactly, ive explained that before to drft so he knew
progress also dont have the ground clearance problem that some people have had with whitelines
but theyre the same diameter, same 3 way adjustable front and rear
JNM240
Ok, well http://www.sportcompactonly.com is down. It gives runtime errors, and a google search came up with the same site that doesnt work. Bummer, really wanted to see these bars. So do they come with new endlinks?
240DRFT
i dont recall if they do or not, but who cares, get soild endlinks. SPL has some, but are on backorder
a_ahmed
Car: 1991 240sx fastback
largus for the win... largest ones no pun intended.
whiteline endlinks suck... they are worse than stock so go with the aftermarket solid ones from SPL if you're sticking with the whitelines..
JNM240
Ok, why do you say the Whiteline endlinks suck? They look alright by me, do you have any experience with them? They have poly bushings, all the other sway bars dont even come with new endlinks. And yes, SPL's heim joint endlinks are backordered, let alone they are $55 more per bar. So how are they worse than stock? Seriously, i am about to order the Whitelines, but i want as much information as i can get. Thanks!
a_ahmed
well if you're going to get the whitelines, get the SPL endlinks... because the whitelines endlink design is worse than the stock ones. That's all there is to it. It's just that. Then they'll be fine... they are just poorly designed.
http://www.splparts.com/Parts/...s.asp
Q45tech
The selection of roll stiffness depends upon the tires one is using and the temperatures of the road surface.
+- 10% ~~= +- 15-20 pounds per inch at the tire road interface can be significant.
jr_ss
Car: 95' S14
I absolutely love my Whitelines... Only gripe with them is the endlink design, but that can be fixed... Awesome bars and some of the only that are adjustable..
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
white lines for sure...I heard they provide just the right amount of stiffness, plus they're adjustable. To reduce Oversteer (Stiffer front/ Softer Rear) To reduce Understeer (Softer Front/Stiffer Rear)
Bosrudorfer
Car: S14
I run stock w00t w00t
sleepyRPS13
Car: to sleep
largus solid endlinks are available for the front only...its similar to spl or the other way around.
http://www.autornd.com/catalog...ddb23
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
JNM240 wrote:Im trying to decide on some sway bars for my S13. What would you guys get? Im torn between the Whiteline and the Tanabe Sustec. I included the Largus and the Cusco for you ballers, but seriously, which ones and how come? If i left any out post em up as well as links where to buy.
Does anyone know anybody who has actually bought a set of Largus Sway Bars? They seem to be like a big budget movie with lots of hype and I'm just wondering if they really live up to it. Don't get me wrong because I'm looking for a set of sway bars and I would like to have a set of Largus but not if I can get a set of Whitelines or Tanabe for comparable performance and much lower price.
naed240sx
Car: .....
Not too many people actually have them. What we do know is that they are quality, adjustable, and stiffer than all other bars on the market. That is pretty much all you need to know to make a decision.
oki_bum
Car: SR Powered 1990 240SX
The Largus Sway bar doesnt clear the greddy oil pan on S13's......so says several sites that sell it. I myself have a greddy oil pan and after reading this thread i might go with progress bars w/SPL endlinks. Cuz my endlinks are crapped out.
oki_bum
Would the SPLs stock give the car a harder feel than the urethane ones? for example using pillow ball tension rods over the stock type.
naed240sx
Car: .....
oki_bum wrote:Would the SPLs stock give the car a harder feel than the urethane ones? for example using pillow ball tension rods over the stock type.
Well anything that changes handling is gonna change ride qualty in some way. It's not gonna be much though. Hell, tension rods don't even affect ride quality much.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
I have a Tanabe rear bar, and love it new endlinks would be nice, but you can pick those up for 45 bux and id father do that then run those ghey whiteline endlinks, and for front sway bar ill prolly go tanabe too
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
i have the 27mm and 22mm sway bars from whiteline, although ive never adjusted them be4, how big of a difference do you feel, i have them on the end of the bar, would i feel anything if i bring it closer?
Driftless240
Car: 1991 Hatchback
Bump... I would like to see this keep going. About to make a rear swaybar purchase, already have front that came on the car. Old School Suspension Technique... Was going to go with Whiteline but now thinking about Progress...
