which suspension mod is next?
mrayburn240sx
Car: Nissan 240sx
i have coilovers, a vlsd, and a rear strut bar. Which few suspension mods should i do next for a good drifting car? i was thinking rear sway bar or rucas? how important is good rucas? Your imput is appreciated thanks...
ohh and ive replaced the front sway bar bushings with polyurithane bushings, and replaced one of the tie rods a while ago. I kind of wanna focus on the rear of the car that being said what are the most important suspension mods i can do next in the rear?
Modified by mrayburn240sx at 3:34 PM 9/22/2008
89twoforty
Car: 89 fastback
It probably won't hurt to start replacing a good amount of the suspension parts. I don't know what year your car is, but those parts are probably 15+ years old. =]
If those are your choices at the moment I would probably go for the rucas.
MJH240SX
Car: 1990 240SX Hatch, 2010 Mazdaspeed 3
I agree......
I would get a full Energy Suspension bushing kit, and new steering components (tie rods, etc)....that would be a great start with a world of difference
89twoforty
Car: 89 fastback
Before I slide my car I plan to replace at least most of the old suspension. I'm probably just being paranoid, but it couldn't hurt.
I'd probably start out with bushings (as said above), and then new control arms, tie rods, etc etc.
240lookis
Car: 1990 240sx hatch
i agree with everything above. new sway bars (maybe godspeed) and rucas would be my first choices.not to threadjack, but how would i know which bushings to replace if i bought the energy suspension bushing kit?
danielsan
Car: 1991 240sx coupe SE
the kit has instructions and tells what bushings go where. i had them on my 90 integra and it was easy as cake.
wynnEZ
Car: 90 240 CA POWA!
a decent lsd if your drifting. vlsd wont do crap.
240lookis
wynnEZ wrote:a decent lsd if your drifting. vlsd wont do crap.
or just weld that ****
Razi
Car: Moo
Grab a Nismo Power Brace or the brace from Jonnie Fraz in our Fabricator's Market section.
adrianfromthecastle
Car: 1992 Nissan 240sx
MJH240SX wrote:I agree......
if you're building a drift car, you DON'T want to get polyurethane Energy bushings. Bushings, whether they be rubber or polyurethane or whatever soft compound, is made for better handling, comfort, and grip. For a drift car, you're gonna want to get the stiffest suspension available, which means replacing the rubber bushings with METAL (pillowball ends). In your case, you're gonna want to get adjustable arms (which replaces oe arm bushings anyways). Start out with the basic arms needed for a proper alignment: rear upper control arms, rear toe, tension control arms, inner /outer tie rods (the one with the spacer on the rod ends). Also, get aluminum subframe spacers, and replace the subframe bushings with solids if you need to.
and get rid of that vlsd. find yourself an open diff and weld it (or if you have money, go with a 2way lsd)
