Which staggered set is best
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
infg35coupe
Car: 2006 Infiniti G35 Coupe
Which staggered set do you think is best for the 06 g35 coupe w/ 19 inch OEM?
Modified by infg35coupe at 6:48 AM 3/22/2009
infg35coupe
yes i do realize i posted same answer twice lol
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
wwww.1010tires.com and use the tire size calculator. That is the best way to determine so you can get as close to possible as the same diameter as the stock size tires.
infg35coupe
yes i realize that but this is to see other peoples personal opinions
RED_DET
Vendor
2011 Infiniti G37x
Doesn't matter what the opinions are, because their opinion maybe completely wrong as far as what is the proper fitment.
If you want to run a wider tire, then your best option is 245/35/19 front and 275/35/19. 275 is the widest tire you should run on that 8.5" wheel. 265/35/19 will work as well. This will put the diameter of the up-sized tires around 1.5% too fast compared to the oem sizes. This will give you a bit of advantage on gearing as it will make the gearing shorter and improve acceleration.
joe603
Car: 2014 Durango R/T
RED_DET wrote:Doesn't matter what the opinions are, because their opinion maybe completely wrong as far as what is the proper fitment.
+1
I'm running 245/35-19 and 275/35-19 on my 05. I would either go with this setup for a wider stance or stock sizes. The rims are not very wide and cant support (safely) a wider tire.
Now you have to find a tire company that makes those sizes....I've got a set of Toyo Proxies that are much better than OEM! So far I have 18k miles on 'em and have about 2k left of tread.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
