touchè sir!TKOcrewSR wrote:s13 black top engines went up to 98 so yes redtops are older but s13 blacktops are around the same year if not newer
purely aesthetics...I'm running a 93 redtop SR on my 92 s13TKOcrewSR wrote:adrian what car and engine do you have. and why dont you agree witth it just wondering what your reasoning is.
TKOcrewSR wrote:yeah you are right you can get black tops with the same or even more mileage but if he wants to go cheaper its better to go with the s13 motor which ever model but i wasnt just saying to go with the blacktop i suggest going with an s13 engine as if he were already planning on upgrading cams and turbo it would be worth it to save the initial couple dollars in the beginning if hes upgrading. plus my full bolt on t28 swap was 300 buck from importintelligence.com . i only work a block away from the shop though and he did my swap.
No you don't. There are plenty of aftermarket camshafts that retain VTC.TKOcrewSR wrote:when you start making more power your gonna have to get rid or vvt if you go with cames
There really aren't that many differences. The turbos have the exact same specs, except the S15 turbo exhaust wheel is made of inconel and has a cast divider wall in the exhaust housing between the downpipe discharge and wastegate discharge. The reason the S15 engine is rated at more HP is because it uses larger injectors stock. If you want to use an S15 engine/6 speed trans you'll need the driveshaft and rear end to go with the trans. You could use a S13 or S14 SR trans on an S15 engine.95s-14 wrote:what's the difference between the s-14 sr and the s-15 ar besides the 6speed transmission with the s-15? Would an s-15 be any harder to put into a 95 s-14 shell?
