which SR manifold?
pull'nslide
Car: s14 Kouki
Which manifold would you get? I hear megan is good and also bad so which would you purchase for an S14 SR.Megan racing-http://phase2motorsports.store....htmlSilk road-http://phase2motorsports.store....htmlPeak Performance-http://phase2motorsports.store....html
The Peak Performance seems to be my favorite, I dont rly wanna pay 600 for a manifold, I cant get JIC or HKS, there like 800, too much. What do you think?
Sorry if this is in the wrong section, this might be more in SR section.
Modified by pull'nslide at 8:25 PM 2/7/2007
E7-S14
Car: ess 14 foo!
if you wanna save money Id go with the Megen racing manifold.The Tomei manifold looks the beefiest out of all of them..( best quality??)
but id go with the Silk Road.. i like this one the best...good price and looks good
i would scratch the Megen and Peak performance(unless your trying to save money)
Thats my imput
pull'nslide
Car: s14 Kouki
I'm actually going to take off the Tomei manifold, its top mount and I need bottom.Anyone else?
chicos240
Car: 1995 240 SX
Peak performance...good bang for the buck
574-240sx
Car: Nissans, Toyotas, Subaru
I have a megan manifold so far so good. I don't think its worth spending that kind of cash on a manifold unless its top mount T3.
notslow
Car: Nissan Sileighty
bump for megan. probably the way I will go.
adrianfromthecastle
Car: 1992 Nissan 240sx
i'm going the tomei route. iirc, i head you have to modify the megan to make it fit right.
blackieblack
Car: 240sx s13
yeah i was going to go with a full race manifold wich is made to order. but i think best bang for buck is megan. if it breaks. its cheap to buy.
574-240sx
The Megan manifold fit with no modifying.
AmoebAssassin
Car: 1991 Base fastback 5spd, black
574, did you gain any spool time going from a cast stocker to the megan?
574-240sx
Tell you the truth it really wasn't noticeable if there was. The more I read I should have just kept the stock one on. I got it for free with the car at the time and it just came out, so I threw it on.
pull'nslide
Car: s14 Kouki
anyone else? Its just those 3, tomei is topmount I belief, or at least all the picture of ppl with it it was. So its out. What do you think, mostly likely a GT2871R will be the turbo I use. If I go Megan I will be using an OEM gasket since I hear the one it comes with sucks. I hear its rly prone to cracking, I hear to make it last u need an good set of mounts and possible a torque damper.
574-240sx
Yes use OEM gaskets. I replaced mine after it was on the car 4K because the gasket they supplied fell apart.
FusionR300zx
Car: 1993 300zx/1997 240sx
pull’nslide wrote:anyone else? Its just those 3, tomei is topmount I belief, or at least all the picture of ppl with it it was. So its out. What do you think, mostly likely a GT2871R will be the turbo I use. If I go Megan I will be using an OEM gasket since I hear the one it comes with sucks. I hear its rly prone to cracking, I hear to make it last u need an good set of mounts and possible a torque damper.
you from chicago or just chicago land area?
i was thinking about gett the stock manifold (Extrude honed/Swained) but idk where to get it done around here or how much it will cost. then i wana think about buying the ebay intake manifold... my freind has one on his and said it's lasted him about 2 years now and he drives pretty hard.
unless soem1 can prove it otherwise.
pull'nslide
Car: s14 Kouki
land area.I'm going to get my swap done at touge factory, they would port it for u.
FusionR300zx
pull’nslide wrote:land area.I'm going to get my swap done at touge factory, they would port it for u.
how much are they charging you for the swap including the engine/transmission price?
IM me.... FusionR300zx
FusionR300zx
did u IM mee? cuz some1 did and i clicked close cuz i was typing to someone and the space bar closed it on accident... if so IM me again, sorry.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Don't buy Megan. Save your money and get the Full Race manifold. It doesn't matter if you don't want to spend a lot. There is a reason why they cost so much. They have been said to increase spool buy over 700 RPM. That is nothing to sneeze at.
pull'nslide
Car: s14 Kouki
isnt that a topmount?
redtop91
Yeah. But like aformentioned it kicks arse.
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
Bump for Megan on the bottom mount manifold. It definitly gained me 20+whp over the stock manifold. Took my trap speeds up a decent bit higher too. Went from 114mph (stock manifold) to 117mph (Megan manifold). No spool difference but definitly helped in the top end.
DrifterProdigy85
pull’nslide wrote:I'm actually going to take off the Tomei manifold, its top mount and I need bottom.Anyone else?
Tomei Supreme manifold is bottom mount as far as i know. Probably one of the best looking and quality manifolds IMO.
Boda
Car: Nissan Silvia Tuned up SR20DET s14a (Kouki)
I`m driving with the Megan manifold and I havent got any problems with that manifold. Works fine for me
Shaefer Thomas
Car: 1992 240sx
Im going to get totally flamed for saying this but...... Im voting for ssautochrome on this one man. I know ALOT of people have had bad experiences with them in the past for some reason, and they got a bad name. I bought an ssautochrome exhaust and it is insanely nice for the money. Its the same as the Megan, if not better. Heres pics of my manifold. They speak for themselves.Ive had no problems with it at all. And its tubular, so theres going to be gains.
redtop91
Shaefer Thomas wrote:Im voting for ssautochrome on this one man.
Newtype
Car: RB26 S14
Anybody still remember the guy named randy who makes manifold himself and sells them on ebay.. Ive heard nothing but good things about them and they are built to full race spec's. For only like 500$.. His email is [email protected] Give him and email andim sure he will give you a link to an ebay site so you can check it out. That is if he is still doing it. I havn't heard much about him in a little while.
Shaefer Thomas
Car: 1992 240sx
I know right.... I wanted to hate it sooo bad after I ordered it and put it on, but its sooooo nice for the money.....
DuckyD
Car: 1995 240SX
adrians_s13 wrote:i'm going the tomei route. iirc, i head you have to modify the megan to make it fit right.
You have to assemble the support bracket. It takes all but 5 seconds.And you do lose your stock oil-catch-can (if you have one).
oki_bum
Car: SR Powered 1990 240SX
full race makes a bottom mout ex. manifold. I have a megan. Started leaking 3 months after i got it. I chucked my stock one and i wish i didnt. I guess its really a gamble...w/ ssautochrome and megan. Some people have gone a year withought any problems. I have always had bad luck, so i guess i should have expected it to happen. I saw the tomei one, but i think im gonna stick with th full race one...just have to save the money. Its pricey, expecially for a bottom mount.
DrifterProdigy85
No modifications need done to make the Megan manifold fit. Support brace is on the manifold itself and doesnt effect fitment, wether its there or not. Also you can keep the oil catch can. Just has to be mounted further away in between the brake cylinder and head.
