which sr is best?
Incubusfu
Car: music,sleep,cars
I have an s14 and want to do an sr swap, i was gonna do the s15 swap until my friend told me the 6-speed transmissions are pieces of junk, so what sr motor would you guys recommend?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
For a S14,Id put the S14 blacktop motor.Its the one that sould be there in the first place.
Modified by 9240sx at 8:17 AM 10/18/2004
mynismo
9240sx wrote:For a S14,id put the S14 blacktop motor.Its the one thats sould be there in the first place.
i agree. put the motor that it was intended for in there.
Silvia007
Car: 93 Nissan 240SX SE Fastback
If you don't want to complicate things, installing the a Zenki into a Zenki and installing a Kouki into a Kouki would save a LOT of trouble. I learned the hardway.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
I don't get why people say the 6spd transmission is weak? I've never seen anyone break their's or complain!
nissanrcer240
Car: 90 Nissan 240SX SR20DET
nnkfws333 wrote:I don't get why people say the 6spd transmission is weak? I've never seen anyone break their's or complain!
I know, I hear this alot too but never see anything bad about them actually breaking? Wheres this info coming from?
Ralph
Car: 1996 240sx
The info is crap, the rumor is said for the transmission to have issues after 300ish whp. We swapped a S15 into my friends S14 and its pretty nice having the 6spd transmission AND the SpecR rear end. That thing gets sideways in a hurry and will lock up with almost no effect. As far as motors go, one isnt really better than the other IMHO, just depends on your goals and how deep your pockets are OR if you know somebody that knows someobdy, blah blah blah...
lee_harvey
Car: 93 nissan 240sr
i would go S14 blacktop into an S14. A friend did a redtop into an S14, it worked ok but it always had problems.
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
Try to get same year. I have a OBDII S14A motor in my OBDI S14B, still trying to get the kinks out.
Ralph
Car: 1996 240sx
See I would have to disagree with not swapping a redtop SR into a S14 chassis. I did the swap into my own car using a clip I bought for a reliable source. I've never done ANY Nissan work before and I swapped the motor out of the clip(SR)out of my S14(KA) and put the SR into the S14 chassis in two days, by myself in my backyard. If you do it right the first time, you should have any kinks or problems of any kind. IF you dont know how to do the wiring, spend the $200-$300 and let someone tackle the issue for you, thats appears to be the biggest problem for most of the people swapping the redtop into a S14 chassis.
Incubusfu
well cant someone give me some specs on the quarter mile and others for both the redtop s13 and blacktop s14. I know redtop has better low end and blacktop has better high end.
Doomed2Walk
Other way around. S13 redtop/blacktop use high port design for top end, S14/S15 notchtop use low port for better low end. S13 SRs are the better choice for high HP numbers and you don't pay the extra money for VTC, which you lose if you get cams anyways.
Silvia007
I can take my buddies S13 with S13 blacktop with my S13 with S14 blacktop
Silvia007
Running same boost, same intercooler, he has 3 inch 5 Zigen Rocket, I have 2.5 inch BRM, I have Catco high flow (punched out coz it melted) and he has stock 2 incher cat punched out, I have stock dump pipe he has aftermarket, I have trust downpipe, he has generic, I have T28 turbo, he has S15 turbo with S14 compressor (something fell in his S15 turbo and messed up his fins), he has 300zx mafs, I have stock SR20 mafs, he has AFC to controll fuel, I have stock ecu and couple of other mods.
SoCalS14
Car: My car...duh
S14 hands down.
Incubusfu
any of you guys know a reliable place i can get one? And also a full s15 front end conversion?
240DRFT
i think you should get a s14 sr, newer...less mileage...possibly better condition than s13 sr
Dori Dori
Car: Cars of course
That's not always true! My S13 SR came out of a 98 180sx and had 12k (or was it 18k) kilometers.
As for the best SR, that's up to you and what you plan on doing. If you're going all out, get an s13 black top. If you're a bolt ons kinda guy, get an s14 or better yet, and s15 sr. Don't worry about he 6-spd...it's a rumor started by Super Street a couple years ago...yes, super street...why this rumor has progressed the way it has is beyond me. I know of a few 6spd's making power that haven't had any problems...I haven't seen one failure on any board either.
sgpnismo
lee_harvey wrote:i would go S14 blacktop into an S14. A friend did a redtop into an S14, it worked ok but it always had problems.
im sure it was just the engine, not that he put it in a s14.
