Which springs will lowered 89" hatch the lowest???
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Hi,
I have SPRINT springs on my hatch for some time now, Im buying new shocks and would like to go to a different springs that will lower my car more. The SPRINT only lower about 1.5 inches and the rear stays up kind of a "dragster look"....any other spring that will give me a lower and even stance???Im not interested on coilovers,etc. because of the extra expenses and dont need the car lower than 2 inches(is a daily driver) to keep my alignment on track......
daz1320
Car: '93 vert
I have sportlines on my car and its pretty low.I think Eibach says "2.2f "2.5r as far as lowering distance.Mine might be for sale for the right price..Also my alignment print out says that i am just within factory specs after being adjusted...
amolao
SO there was no need for a camber kit???you have any pics???like to see how much they drop your car.....how old are they???
Fenvy
Car: 2005 350Z Base 6MT
you WILL need camber kit
amolao
how much will the camber kit cost????
Will I need front and back??
thanks
daz1320
Car: '93 vert
They are about 7 months old.I'll see if i can dig up some pics.Camber kit??? definitely not needed...
Exar-Kun
Car: 2005 350Z
anything over a 1.5" drop should get the alignement checked and a camber kit installed if necessary..-chet
amolao
Hey Daz , what struts are running with those springs?????
daz1320
Car: '93 vert
I just have the stock struts.my car actually rides pretty much like stock.Its not bumpy at all.After I put the springs on i didn't check my alignment for 4 months and I didn't have any abnormal wear.When I take pics I will take pics or my tires too..sent me an E-mail..my adress is in my sig.
daz1320
Car: '93 vert
Ok We were slow at work today so i put my car on the alignment rack and this is what it read
front: left front right
nominal -.75 ,min -1.50,max 0.00 actual -1.2 actual -1.2
rear rear
nominal -1.10,min -1.60,max -.60actual -2.1 actual -2.0
..of course i left some parts off but basically the front is within specs.The rear is not.Everything else is ok.All in all my tires do wear fairly evenly
daz1320
Car: '93 vert
i tried to send pics but your e mail was full
