Which speakers for factory replacement
charlespsu
Car: 2010 Nissan Rogue Krom
So I've seen ALL the threads about speakers sizes, etc. I already know the front is 6x9 with a 3" depth.
The problem I'm having is Crutchfield is telling me only two speakers will fit the rogue.
Is this true? Is the 3" depth a real problem? What speakers have you upgraded without any modification?
Thanks!
rdub2k4
Car: 2012 Nissan Rogue SE
2011 Mitsubishi Lancer GTS
There's tons of ways to get speakers in the front. And you also don't HAVE to use a 6x9 up front. You can use a 6.5" (which to me, round sounds better then oval) with an adapter.
Here's some decent 6x9's which will fit.
http://www.sonicelectronix.com/item_639 ... 6965R.html
http://www.sonicelectronix.com/item_271 ... -6090.html
http://www.sonicelectronix.com/item_433 ... R1694.html
http://www.sonicelectronix.com/item_189 ... 633cf.html (work with a small baffle, probably sound the best IMO)
http://www.sonicelectronix.com/item_618 ... 602ix.html
These are just some of my recommendations on 6x9's.
Return to “Rogue Forum”
