which slave cylinder
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
when you guys did your SR swaps what slaves cylinders did you use? did you use the KA transmission one, or did you use the SR transmission and then just bleed the clutch?
~swave
VitaminT
Car: 93 240sx SE
I used the SR, but mainly because it looked newer/nicer. They looked to be the identical part.
daz1320
Car: '93 vert
They are identical.My KA slave went bad so I used one of my sr slaves.worked perfectly.
D1SR240
Car: 2002 BMW M5
1991 Nissan 240SX
alright thnx guys, i wanted to know for future referance.
~swave
DriftS14
Actually, they are not identical. The SR Cylinder is 3/4 while the KA's is 11/16. Very slight difference, but the 3/4 cylinder will allow for slightly better pedal feel.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I just ordered a new one at nissan and went with a taka line to eliminate the air trapping, mushy pedal making antibleedinator box.
