Exar-Kun wrote:well, konis have to be cut for installation, have fun with that...other wise, its a great damper.-chet
Actually, the old front OE struts have to be cut and then a hole drilled in the bottom. The Koni's bolt in to the old housing. The ones for the rear are a straight bolt in.
Since this has already been installed in another car, the hard part should be done already. IMO, the Koni's are much better shocks than either the Tokico's or the GR2's. I believe the Koni's can be re-valved too, if that's important to you.
As long as the Koni's are in good shape, I'd personally go with them.
They are coming off another S13, right?
