skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Wed Sep 08, 2004 4:02 pm
If you look at the Nismo unit, it's not even called a 'short shifter' it doesn't reduce the throws, hence it's called a 'solid shifter' It looks identical to the OE unit, being that it's a single piece, maybe it's heavier, by looking at it, i don't see what's so special. I think it's a jip.
The B&M is a nice unit, overpriced too (compared to B&M units for any other vehicle, ours cost the most ) I've heard good about it, but i've also heard some whiners complaining how easy it is to accidently miss a gear/or shift into the wrong gear because the throws are so short that it's hard to feel the 'H' gates. And then there's the rattling. As for me i have an ebay unit that's based off the C's short shifter made by RVM. I don't like it, mostly because the bushing is too small compared to OE. I will either try to fix the bushing, get a different short shifter altogether (maybe a Pilot instead) or there's always the Tanabe Sustec transmission brace, it's a urethane bushing that goes between the transmission and the transmission tunnel to reduce transmission movement while shifting.. PLUS they give you a metal bushing for your shifter and a couple of clamps to help stiffen things up.
