which s13 wheels fit 3z brakes
dvs240
Which s13 wheels fit over 3z brakes.. I know there is 1 s13 wheel from 91-94 that will fit. But i dont know which one.. What size rotor would I use if I use the s13 wheel w/ the 3z brakes. 10"? 11"? thanks guys
Nismo_Freak
Car: 89 Nissan 240SX
Rotor isn't the problem... obviously a 15" diameter wheel will fit over an 11" rotor.
The caliper is the problem... You can fit the OEM 91-94 SE wheels with a 10mm spacer.
