Which s13's have LSD?
mr_wizard
Man I looked everywhere. Here, FAQ, googled.... and I think I came to the conclusion the SE's have LSD? Or just HICAS?
Toshima
Car: 93 240sx, 93 sc300(m/t)
Just the HICAS on the s13 and s14 i thing its the ones with abs. I have a parts 93 s13 se and it had no vlsd but it didnt have HICAS ether.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
That may be correct. Certain models from 89-98, all years had LSD, but I can't remember exactly which ones.
struckinc
Car: 93 hatch.stock.well mostly anyway-SOLD
97 kouki-stock
12 sentra sr-wifes new car
97 maxima-wifes car-SOLD
02 maxima se- daily
1936 austin 10/4 lichfield
sorry double post
struckinc
97 kouki-stock
02 maxima se- daily
i believe the s13's with abs and hicas came with lsd...are you looking to do a swap? because the easiest is the 95-96 j30..same axles-spline pattern mounting--jsut have to swap the rear cover-just make sure you get the front mounting bolts--(the lsd bolts are longer than reg. r200 bolts)...also non turbo 300zx bolts in but you have to use pre 95 j30 or 300z axles because of the bolt pattern..same as the others you have to swap the rear cover..the s14 uses the same 2 bolt mounting that the j30 and z uses but s13 used a 4 bolt mounting rear cover
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
i'm pretty sure the only s13's with a LSD is the SE hatchback with hicas and abs
