Which rims will clear the 300zx 4piston brakes
dvs240
Hi, i purchased 4 piston calipers from a z32 and rear calipers + rotors. I need to know which rims will clear the brakes.. I'm not converting to 5 lug, so im stuck with 4..i'm interested in rota rims for thier price, decent quality, and weight.. but which rota's will clear them? i'm interested in any lightweight, decent priced, 4 lug rim. Please i need some suggestions, thanks guys!
dvs240
oh yea, im looking for 16's or 17's..
captain nismo
I believe clearance depends on the shape and thickness of the the spokes on the wheels. It sort of a test to see if they will work sort of thing...
Sid3ways S13
Offset is also a VERY important issue to make sure that the wheels will fit. Check the offsets before you buy as well.
Exar-Kun
Car: 2005 350Z
offset will help in determining wether or not the wheel will clear, but spoke design(inverted,straight, outverted), sometimes a wheel may fit the 26mm brakes and not the 30mm.....test fit is usually required, esspecially if the offset and size is suspect.
also, rim design in a 16" may determine if the wheel fits or not-chet
Grant@tirerack
Car: Auto racing (AMLS, Cart,F1,IRL in that order), old show rods, classic monster and bad sci-fi movies,
That's something you will have to test fit on the car to know for sure.
