exode »
https://forums.nicoclub.com/exode-u48159.html
Sun Sep 09, 2007 6:18 pm
If you live in a cooler climate area and don't have alot of heat mods (bigger turbo, added boost, blah blah) you honestly would be fine with the 300ZX Twin Turbo Rad Cap, which you can get at autozone for like $12. Its rated at 1.1bar (bout 16 psi)
I have alot more power adding (and heat adding) mods installed and I run a lot more boost. I run the same radiator and have a Nismo rad cap which is rated at 1.3 bar (19 psi give or take).
