Q45tech wrote:Before you decide to replace a leaking rack try Lucas rack sealer additive.
Careful many low cost remans are nothing more than cleanedup, repainted, used with a few new seals.
Need new rack mount bushing to mount a expensive or cheap rack.
Most shops by racks without solenoid pressure valve and clean old one and swap on to replacement rack.
PS "Careful many low cost remans are nothing more than cleanedup, repainted, used with a few new seals." what do you think any rebuild is on any rebuilt part it is a used part that is cleaned resealed and tested.
There are many rebuilders that practice the spray and pray method or fluff and buff but they never last long.
here is a little secret for you all if you pull the passenger side bellow look and see if there is a little hole drilled in the casting where the bellow is clamped. The unit can not be rebuilt or has not been rebuilt if there is no little hole drilled there because when you remove the Bulkhead the threads will strip out because nissan / Infiniti stamps the casting to lock the threads. this stamp must be drilled out. so this is how you can call a bluff on a rebuilder in the event they deny this ask them to open it while you watch you will have fun with that one......... the casting is steel and the bulkhead is a fine thread aluminum so if they try to turn the bulk head loose with out drilling the stamped notch they will get about 2 turns and the bulkhead will lock up and will not turn in or out. the fine aluminum threads build up in the steel part of the casting. at that point toss the rack in the scrap pile............
Good luck
Be well Rack Doc
