qsiguy wrote:So what's the big deal with sodium filled exhaust valves besides sounding cool?
The sodium inside the valve stem helps pull heat out of the cylinders. Another reason to turbocharge the VH45.
http://www.aa1car.com/library/ar1192.htm
Any valve will eventually wear out if driven enough miles. But many valves call it quits long before they should because of burning or breakage.
Let's talk about burning first. Exhaust valves are the ones most likely to burn because they run hotter than the intakes. The intake valves are cooled by the incoming air and fuel, and consequently operate at about 800 degrees F. Exhaust valves, on the other hand, receive little such cooling and are blasted by the hot combustion gases as they exit through the exhaust port. Exhaust valves run at 1200 to 1350 degrees F. on average, which makes them much more vulnerable to erosion and burning than intakes. The higher operating temperature requires a tougher alloy, so exhaust valves are usually made of stainless steel or have stainless steel heads (typically 21-2N or 21-4N alloy with a high chromium and nickel content). For heavy-duty gasoline and diesel applications where heat is even more of a problem, a tough Stellite facing (cobalt alloy) may be needed on the exhaust valve face to control wear.
The intake and exhaust valves rely on physical contact with the valve seat and guide for cooling. About 75% of the combustion heat that is conducted away from the valve passes through the seat, so good seat contact is essential to prevent burning. The remaining 25% of the heat is dissipated up through the valve stem and out through the guides. Sodium filled hollow valve stems in heavy-duty applications are sometimes used to draw even more heat up through the stems to aid cooling.
