frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Mon Sep 27, 2004 4:27 am
Thanks for replying! All pumps have made the whirling noise. Each time a pump was installed, connected, filled, and bled correctly (as by Chiltons anyway).
About your idea of not having enough fluid...After the whuring, I decided to drain the fluid, run the car(I ruined the pump previously before, it couldn't hurt) and add fluid. The odd thing that happened was that after about 1/4 of a quart made it in, the whuring began. Same result with p/s and ATF. Thought it was odd though.
Other tidbits: -The pressure line gets rock solid and vibrated tremendously each time. Definitely not normal.-Upon looking at a diagram, I noticed that I was missing the washer between the pump and the pressure line. However, I'm not to keen on thinking that a washer missing is going to cause the situation I have. I'm not to willing to throw away cash for another used pump and find out that the washer wasn't the issue. -Which brings me to where I am now. If I buy a new one and I get the same result, I can bring it back, say it was the wrong year and didn't fit (or some other excuse). Buuuut, I don't know which year to buy new. The 90 (year of the car and steering rack, but I'm not sure if it will mount to a 95 block) 91-93 (year of the lines that I needed to make the swap possible) or the 95 (year of the motor). -I am going to a junk yard that has from what I hear, a plentiful amount of s13s. I could take the 89/90 pressure line and try to hook it up to another pump, but again I am at a loss for what year to buy.
