which power fc?
turbocarslut
Car: 1989 Nissan 240sx (hatch)
2011 BMW 535xi
Hey could you help me… I want to purchase a power fc but for some reason the Apexi website has three different version. I am putting my s13 blacktop into my 95 240sx…which one should I get?
414-N014 91-94 180SX RPS13 B/M/C (Red Valve Cover) $980.00/$350.00414-N014 91-93 Silvia PS13 (Red Valve Cover) $980.00/$350.00414-N015 91-94 180SX RPS13(Mid Minor Change) $980.00/$350.00
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
Well lets rule out the two redtops because you said you have a blacktop. Now if your blacktop falls into the correct year, its choice #3, if not call them and tell them what year you have. To check the year of your motor set, look at your ECU for a year printed on it somewhere. Only reason this is important is for the plug and play compatibility you will get for buying it. Getting a redtop version will not plug right up and go.
I H8 UR DSM
i'd call Mckinny motorsports or phase2...i know mckinny knows with power fc is right...
ItzGenX
Ok I figured it out. Before minor change means BEFORE OBD-II came out. After minor change means you have an OBD-II motor.
