Which pair of lowering springs goes to the front?
AlexAlexAlex
Hello! i got a set of lowering springs...just wondering which pair will go the front......it looks like these two pairs have different spring rate....please help!!
Q45tech
Stock springs are 146 F / 123R and that ratio 54% front 46% rear needs to be maintained as that is the weight ratio.
qship96
Car: 1996 Infiniti Q45
But the lowering springs make the car look sooo cool, I dont care if they dont function as well as the stock ones,all the KIDS at school have them on their civics
superuber
What kind of springs are they? Pics work wonders! The shorter springs go to the front. When you take them off it's really easy to see what goes where. Post some pics and we can help. Hopefully thats a help.
Modified by superuber at 7:47 PM 3/11/2008
qsiguy
Car: 1994 Infiniti Q45 Turbo
Super, Amen brother! An actual helpful post.
After I looked at my Cali Customs springs I was going to ask the same question but I figured I could tell when I got the old ones off. Plus I didn't want to get flamed!
(I seldom let a day go by that I don't pick up a wrench!)
AlexAlexAlex
yeah...I got the Cali springs ..I guess the set with more coil counts should goes to the front.. But not too sure.. So far I had replace the front sway bar bushing and custom a front strut bar using z32's...hope these springs can stiffen up the ride a bit.
superuber
They will stiffen it up. Don't worry, you'll know which spring goes where. Kind of a no brainer! Good luck.
Rex
Car: None
AlexAlexAlex wrote:yeah...I got the Cali springs ..I guess the set with more coil counts should goes to the front.. But not too sure.. So far I had replace the front sway bar bushing and custom a front strut bar using z32's...hope these springs can stiffen up the ride a bit.
The taller ones that "taper" go on the front.
Sorry for the delay
