which out of this list of part numbers are the new style guides? i have both metal backed curved ones and just now need the upper passnger new style with the bolts and the lower driver side with the bolts correct?
2x 01121-04711 - bolts for new guides NA
4x 11051-60U04 - cam end seals NA
2x 13021-60U00 - crank/cam sprockets NA
2x 13028-60U00 - timing chains $99.88
1x 13070-60U03 - chain tensioner(RH) $49.90
1x 13070-60U12 - chain tensioner(LH) $49.90
4x 13075-60U02 - tensioner bolts $ 5.20
1x 13079-60U01 - tensioner gasket(LH) $ .56
2x 13085-60U01 - chain guide $13.18
2x 13085-60U11 - chain guide $13.18
1x 13091-60U01 - guide(tension RH) $49.85
1x 13091-60U11 - guide(tension LH) $49.85
2x 13094-60U00 - guide bolts NA
1x 13510-60U00 - front cover seal $ 5.34
1x 15041-60U00 - oil pump chain $33.88
1x 15043-60U00 - crank/timing sprcket NA
1x 15044-60U00 - crank/oil sprocket $33.88
1x 15072-60U00 - bracket oil pump NA
1x 15073-60U00 - oil pump chain guide $ 4.87
1x 15073-60U10 - oil pump chain guide $30.85
2x 13270-60U00 - valve cover gaskets NA
8x 14032-60U01 - intk manifold gskts $24.80
