Unless you are doing full race applications, this advice is worthless. ANY decent oil, syn or otherwise, is good for longer than 4K. It ain't rocket science folks.NOTE: these car run hot in nature as it a high compression high revving motor. another note. The intake VALE-TRAIN is quite picky about oil and its coating and circulating properties. the race oil had much smoother operation up to redline.. if your going to run your car HARD get a oil cooler or run the race oil and change it every 500-1500 miles depending on how hard you drive it..
if your an everyday driver and like to get on it but don't run it hard in say DS down winding roads(me) run the ams and if you have to the Royal purple is OK but if you don't run these get a damn oil cooler..
AgreedStarter wrote:Unless you are doing full race applications, this advice is worthless. ANY decent oil, syn or otherwise, is good for longer than 4K. It ain't rocket science folks.
Ive heard good things about redline. i went with amsoil. i might try out the Lucas oils soon too. needless to say i hear alot of people running the ams.,mobile 1 and Valvoline race oils. the amsoil is the only one i found in 10-30.. i haven't looked online for the others so they may have um( im sure they do).Fezzik wrote:I'm still using redline all these years and no issues.
no its not rocket science. Its chemistry. like i said test it yourself.Starter wrote:Unless you are doing full race applications, this advice is worthless. ANY decent oil, syn or otherwise, is good for longer than 4K. It ain't rocket science folks.NOTE: these car run hot in nature as it a high compression high revving motor. another note. The intake VALE-TRAIN is quite picky about oil and its coating and circulating properties. the race oil had much smoother operation up to redline.. if your going to run your car HARD get a oil cooler or run the race oil and change it every 500-1500 miles depending on how hard you drive it..
If you've done the research you would know that any street motor, even modded, never puts a strain on bearings, cylinder walls, etc. like actual race applications. By race I don't mean straight line speed runs for 10 to 20 seconds. I'm talking thirty minute or more oval and road course events. Most of that time at high RPM. Race oils are formulated more for anti foaming properties because of the sustained high revs and is the real difference between race oils & street oils. Any quality dino or syn oil will satisfy all street applications, even the ones you describe. The real cause of oil degradation is sustained heat, which is where syn oils shine. Your use doesn't even begin to stretch the envelope of what street oils can handle. You should use what you like to use, but it seems to me you could save a lot of $$$s if you were to rethink your strategy.no its not rocket science. Its chemistry. like i said test it yourself.
any oil that is petroleum based is inferior to the real full synthetics .. the main name brands are all conventional oil with synesthetic additives.. they lying to you.. its that simple. if your going to buy those you might as well get conventional oil and add some lucas synth additive..
and full racing applications? if you drive your car hard and in DS where it uses the rev matching even if you don't the superior protection will have less wear and your car will last longer. why not spned the extra money( its along 9$ a quart) and just get a REAL fully synthetic? your just paying for a blended group 3 lub.
