AunVoh »
https://forums.nicoclub.com/aunvoh-u197.html
Thu Feb 26, 2004 3:07 pm
Uh, I don't know about the NAPA filter and non-synthetic oil... I'd go start to Mobil one with a good 10-w40 with atleast a bosch or better filter... If you think that the engine is going to have enough problems with the oil then you should just go ahead and watch the oil, and check it to make sure it doesn't need changing, It might be a good idea to intall a oil pressure gauge when you install the motor, that you can keep an eye on everything while you're using it, it's just a few bucks that could save you big in the long run. Good Luck man~
