which offset I should pick to get this look?
pat93
Shopping GRAVITY Gullflame for S14 Zenki; choices are
18inch 8.5J 114.3 5 +25/+35 9.5J 114.3 5 +15/+25/+3517inch 8.5J 114.3 5 +29/+38 9.5J 114.3 5 +26/+38
(http://www.gravity-style.com/test/whe/whe.html)
which one among those would give me the look of my caras same/closed as this sweet green
Anyways, I'm waiting for Stance coilover. No plan for big brake in near future; My ride is DD. I just need sexy look from her.I prefer 17" and don't want to hurt her by pulling the fender.
Thanks in advances
Modified by pat93 at 1:52 AM 9/24/2007
whiterps13
Car: white LE hatch
Id run the 18x9.5 +15's all the way around. Just stretch a 225/40 or a 235/40 and it'll look badass.
IMO s14's need 18's.
adrianfromthecastle
Car: 1992 Nissan 240sx
whiterps13 wrote:Id run the 18x9.5 +15's all the way around. Just stretch a 225/40 or a 235/40 and it'll look badass.
you might not get the same fitment as the pic unless you get some rucas
nismofly
Car: 89 Nissan 240SX Hatch
if those arent spaced theyre probably the 18x9.5 +12 cr kai's, so the 18x9.5 +15 would be your best bet
either way its the best bet because its the best size gullflames are available in, at least here
pat93
Thanks for every response. Seem like everybody point to 18"Do you think my NA could handle with those 18" wheel?
nismofly wrote:if those arent spaced theyre probably the 18x9.5 +12 cr kai's, so the 18x9.5 +15 would be your best bet
With thankful and respect for your answer, If I said 17"x8.5 + 29 is my choice, how much spacer I could use without changing to longer studs
nismofly
get bolt on spacers, theyre better anyway...like 15 or 20mm
