firstq »
https://forums.nicoclub.com/firstq-u958.html
Sun Sep 08, 2002 5:19 pm
My Q is starts to vibrate right around 30MPH (vibration in the seat, hand rest, and steering is observed with a growling noise as well).
- I have 4 new Yokahama Yk420 ride matched/balanced (2 times) tires (hunter 9700 machine @ discount tires)- The car does not pull in any direction - very straight- Reving up the engine does not bring the vibration before hitting the 30MPH threshold- Manual shifting of gears does not make any difference (happens in 2nd as well as 3rd)- With more speed > 40 MPH - either the vibration lessens or other noises subdues this vibration
Some options I am considering:
1. Do a pan drop and ATF flush with Mobil 1. I had done a flush recently (2k miles ago) but the fluid is not Mobil 1 yet. I removed some of the ATF and the vibration has lessened a bit (but not gone completely). The car just got a new transmission mount, but the vibration is still there.
Cost around $130.
2. Have the car alligned. The car is not pulling in any direction, very straight. But I am not sure when last alignment was done by the previous owner.
Cost = $50 for cheapo place or $120 for the dealership
3. Go for the Drive Shaft.
Cost = roughly $1k
I would really appreciate if you gurus can help me prioritize the next steps. I know number 1 & 2 are not that expensive and should be done alnyways - but if my priority #1 is to fix the vibration, what makes most sense here?
Anything that I may have missed (wheel bearing out, etc)
Thanks.
