Which of these is an OEM pressure plate bolt?
Matej
Can anyone please help me identify which one of these is an OEM KA24DE pressure plate bolt?I have a set of both. I could probably use either, but I would much rather use whichever one came with the motor.Thank you for any help.
psmith
Car: 92' 240sx
Matej
Thanks for the reply. Interesting, I have received mixed answers.
Razi
Car: Moo
Hold on Matej, I'll look at the spare KA I have in my backyard.Be right back.
Matej
Razi wrote:Hold on Matej, I'll look at the spare KA I have in my backyard.Be right back.
Haha alright, thank you!
Razi
Car: Moo
Doh, I forgot the spare KA doesn't have a flywheel on it. It does, however, have bolts that are supposed to be holding the flywheel on and it is the "7" bolt!
gumby74
The one with the 9 on it is correct.
The bolt with the 7 is one of dozens found throughout the engine bay securing random brackets.
Matej
Hmm, ok then, thank you both.
hboninc19
I have a spare clutch kit bolted to a flywheel .........9...............
Matej
Thank you.I found out that the #7 bolts are used to connect the slave cylinder to the transmission. Not sure why I have six of them though, haha. I guess there were more of them connecting other things, as gumby74 said.
Razi
Car: Moo
Haha yeah you can collect a ton of random bolts while taking the car apart.I have a small box filled with bolts I no longer need from my car.
VRoy
Car: 93 S13 Hatch
Just for future reference, the higher the number the stronger the bolt. A chart for this can be found in the FSM. Looking at your torque spec's and the application for the bolt will help out too. That is if you don't get the answer on NICO first lol. Oh and it is a 9 btw.
pungkiteater_671
damm so which one is it ?? i only have 6 of the 7 numbered bolts
and the 7 fits but i dont want it to mess things up down the road !
Matej
It's the 9 bolt.
pungkiteater_671
Matej wrote:It's the 9 bolt.
dammm u serious the only bolts i have that is 6 pieces is the number 7 ones
VRoy
Car: 93 S13 Hatch
If you have a local Fastenal they should be able to order you what you need. They have for us anyway. http://www.Fastenal.com
Matej
At first I was not able to find a couple of my 9 bolts. Searched the entire garage for over an hour until I finally noticed that I used them to hold the hood latch instead of the 7 bolts that are supposed to go there. Maybe you accidentally used yours somewhere else as well.
pungkiteater_671
Matej wrote:At first I was not able to find a couple of my 9 bolts. Searched the entire garage for over an hour until I finally noticed that I used them to hold the hood latch instead of the 7 bolts that are supposed to go there. Maybe you accidentally used yours somewhere else as well.
nah i didnt bolt anything down yet everything is stripped out lol my dad prolly threw it away on accident ... ohwells i just bought a set of bolts from autozone
