With the toyota turbo you will need to modify an adapter plate in order to bolt it to a standard T3 manifold. I would use an adapter so that in the future it you decided to upgrade the turbo you would not need to reweld the manifold.
The turbos are very cheap. I can quote you well below $150 for one with the WG. Cant give you an exact price but I would guess in the aria of $100 for a ceramic turbine J-Spec if I can find one.
Price is the main reason why I was looking at the CT-26. Last time I was over there I had to dig through about 10 crappy turbos for every one good one I found. I got two in perfect shape though
IMO if your looking for a really cheap turbo and you would like one that is in good shape. Your best option would be to buy a Z31 that is worn out and have it rebuilt with a T4 compressor. That way you would have a awsome turbo with plenty of flow on the turbine side and a large enough compresssor and housing so that you will have less heat per PSI. Im not sure what the price is to do the upgrade but, I regularly see the T4 compressor and housing on ebay for just over $100. My friend had his turbo rebuilt and spunn for about $300. So in total you would spend about $450 for a brand new hybrid turbo capable of probably well abouve 300hp.
