3Q Jay »
https://forums.nicoclub.com/3q-jay-u16163.html
Wed Oct 24, 2007 6:07 pm
Mike- i don't know all the ins and outs, but.....your program has more aggressive timing thruout the rev range. robert always mentioned that he couldn't give any more than stock advance at 2000 due to detonation (don't know if that was due to his engine and not trying to get off topic), but the key is from off idle you get a bit more, and then above 2300 or so you get quite a bit more along with some leaning at higher rpm.it retains EGR functionit is not a 93 octane minimum (he did a few of those including a 91/93 switcher for me--for when i move to FL permanent), but does require 91 min to keep from high rpm detonation when the ks get ignored as Dennis was saying.the VVT 4200 means that the VVT turns back OFF at 4200 regardless of throttle position. I think this was stock, most of us asked to extend VVT band out to 4600.7200 is your fuel cut or rev limiter. most of the G50 tachs ive seen read optomistic rpm, so if you wound it out, you might indicate 7500-7600 before fuel cut.redline and fuel cut are not necessarily the same. the redline for your engine didn't change when the rev limiter was changed. redline is typically set to keep alternators from grenading, valves from floating, and occasionaly water pumps from cavitating (haven't heard of the latter as an issue on our engines). in absence of all other limitations eventually the reciprocating mass would come apart. 7600 rpm seems to be the accepted value here for the true (not indicated) rpm limit for a perfect condition VH45DE.in stock ECU form, we should never actually be able to tach into the red zone due to the stock 6900 rev limiter.
