Which NGK spark plug for 1998 QX4
I35JUGA
Car: 2003 i35
Which spark plug that you guys use or recommended ? buddy of mine said get ngk V-power also is it posibble bad/old spark plug cause poor gas milege ? the car running fine but i got about 12m per gallon on city/highway combine. before i got around 16, thanks
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
NGK BKR5E-11 (6953). Buy 6 at Advance Auto Parts online and use discount code P20 then pickup in-store for a total of $11.47 + tax. See FSM page MA-18 for instructions on changing spark plugs.
I'm fairly sure worn or fouled spark plugs can cause poor gas mileage, yes.
Chuck Tribolet
Car: '01 Nissan Pathfinder
'87 Chevy Corvette
'01 Toyota Camry daily driver
'98 Boston Whaler Montauk
Old tired plugs will affect gas mileage.
I'd run whatever the owner's manual or FSM recommends. That's what was in it when the factory engineers determined
the ECU parameters on the dyno.
Chuck
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
I bought the best NGK's I could afford: Iridium BKR5EIX-11. Totally agree with Chuck on whatever the FSM recommends would be fine, I dont ever plan on replacing the plugs again though so figured I would splurge.... Have not installed them yet. Also picked up a set of NGK plugs wires.
