which mounts are best for rb25 swap?
spikee306
Car: rb25 powered 92 240sx
i've been looking around quite a bit and i'm not too sure which are the best mounts to use. i'm probably going to bet getting a motorset as opposed to a clip because clips are too expensive with wanting to replace all of the pumps, clutch, etc...
you guys probably already know this info, but i'm gonna say it anyways to make sure i know all the info.
syko performance has their swap kit that needs the r33 crossmember and brackets. Their kit also comes with an exhaust elbow and sway bar spacers which is nice. and another perk of this is the driveshaftshop has a driveshaft that will fit perfectly with the syko performance mounts. so for this i'd have to find an r33 crossmember, which i currently know where one is..and the guy wants $200 for it...
mckinney motorsports has their kit that uses the stock s13 crossmember. means not having to find an r33 crossmember but having to buy or fabricate to accomodate the LHD.
theres also tophat performance. i don't know too much about tophat...but i'm assuming they are like mckinney and use the stock s13 crossmember.
does mckinney and tophat's mounts sit the engine lower and further back too? i think they do, but i'm not positive on that one.
i'm leaning towards the syko performance because of the extras it comes with.any input on this is greatly appreciated!
imotion s14
Car: 1997 240SX
I got the SYKO mounts and I'm happy with them. Can't really comment on how they compare since I have no basis of comparison. But it's a real nice kit and their customer service was pretty good.
Bluefire
You should search up these mounts as there has been a lot of discussion on this topic already. But i'll throw out some other info. I don't see having a driveshaft with the kit much of a perk. Any local driveshaft shop can make you a driveshaft for around $250-$300. Just tell them what kind of yoke and rear flange your using as well as the length from trans to diff, and thats it. Also using the R33 crossmember means having to bend around the powersteering lines, which I hate doing because it always looks like crap. Also buying a mount kit, is supposed to be a drop in kit for the 240, so there shouldn't be any mods needed for LHD
-Bluefire
s14_sport
Bluefire wrote:Also using the R33 crossmember means having to bend around the powersteering lines, which I hate doing because it always looks like crap. Also buying a mount kit, is supposed to be a drop in kit for the 240, so there shouldn't be any mods needed for LHD
-Bluefire
Eliminate the power steering lines which you should do anyway and get a real power steering cooler for $50.
spikee306
Bluefire wrote:You should search up these mounts as there has been a lot of discussion on this topic already. But i'll throw out some other info. I don't see having a driveshaft with the kit much of a perk. Any local driveshaft shop can make you a driveshaft for around $250-$300. Just tell them what kind of yoke and rear flange your using as well as the length from trans to diff, and thats it. Also using the R33 crossmember means having to bend around the powersteering lines, which I hate doing because it always looks like crap. Also buying a mount kit, is supposed to be a drop in kit for the 240, so there shouldn't be any mods needed for LHD
-Bluefire
i have searched quite a bit about all these different mounts. i'm also trying to get peoples opinions about these so i can make a good decision on which ones to use myself. i haven't really seen any review type posts on here or anywhere either. i juse see that people have used these mounts but they don't say how good or bad they are. if you or anybody knows of any reviews or anything, i would definitely like to see them. im just trying to figure out the best route to go as far as the mounts go.
i've seen that and have been thinking about it, but thats something that i've been meaning to look further into to see whats all involved with that.
spikee306
ok so just as luck would have it....i found a thread (and am assuming there are several more) about people's opinions on which mounts to use. seems to me that syko will most likely be the way to go. guess i didn't look hard enough or use the search bar enough before.
coreansurfer
Car: painted s14
i've had the mckinney mounts for 2 years + now, i've always liked them, and always been happy with them. engine sits low and looks good
mattleegee
Car: s13+19 corolla
im confused on the syko website you get
mounting kitelbow and driveshaft
for $585?
Jimefam
Nope just mounting kit and turbo elbow. the driveshaft you buy from DSS i believe for like $300 for the steel one and $399 for the aluminum one.
nyc240sx
Car: 1995 Nissan 240SX SE
RB25DET series 2
iam going with mckinney since i got a used set on ebay for a really good price.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
dot go with teh tophat mount! holy **** no TOPHAT
rb26tommy
Car: nissan 240sx s14 rb26dett
i have top hat mounts on my rb26 1998 240sx for about 3 plus years now i have put them in my rb20 s13 and 2 rb25 s13 also so they have been working fine for me.
Tenchuu
Car: 97 240
I met up with a local guy last weekend that got the RB25DET S14 mckinney set, he hates them, had to do a lot of customizing to get them to work and his steering binds up on him.
I have a syko kit and was telling him it was a breeze to toss it in.
