Shusaka »
https://forums.nicoclub.com/shusaka-u119906.html
Wed Nov 12, 2008 5:52 pm
okay, realistically, your idea for a KA24DET is already bunk. The amount of money you will have to put into the engine to safely put out 300 horsepower is ridiculous compared to any jdm turbo motor swap. i know because i have thought very hard about doing a KA-T build myself and here is your list of parts: 4 low compression pistons. arias makes them at 8.8:1; 4 forged connecting rods; 1 turbo manifold; 1 turbocharger; 1 FMIC, 1 Set of FMIC plumbing; JWT ECU upgrade; 1 255 LPH fuel pump; 4 higher flow injectors, 555cc for around 7 lbs of boost i think; 1 turbo downpipe, 1 cat back exhaust kit; 1 cold air intake; 1 battery relocation kit, as your charge pipe from the FMIC must be plumbed through your existing battery location; 1 head gasket; 2 upgraded camshafts; 16 new valve stem seals; 1 port and polishing of the head; 16 new valve springs and retainers; and 1 new valve cover seal. I think thats it, correct me if i'm wrong but it will total out to around $4500 for a DIY install, and over 6k at a shop, on top of the price you will pay for the KA24DE. On to your other engines, RB25DET is a solid engine, if you get it out of a RWD skyline with transmission, it will only require custom engine and transmission mounts as well as a custom driveshaft for the proper length, and ecu/wiring harness and i almost forgot the high volume fuel pump. The RB26DETT is a pain in the *** from what i hear, i dont personally know about the specifics of the swap. my choice for you is simply the...*hears crickets and prepares for personal injuries*...SR20DET. PERIOD! It uses the stock KA engine mounts, same transmission mounts, same driveshaft, and requires only the engine wiring harness and high volume fuel pump, with a slight increase in boost, cold air intake, upgraded injectors, a full exhaust, header included, and a spit shine you should be well over your 300hp mark, and the engines are totally reliable, i would choose this engine over any other unless you can find someone who is very good with the RB26 swap and can do it right the first time and warranty it, and if you can't..... to the almighty S14 SR20DET with VCM
