Which motor mount for a stock engine and possible future upgrades?
el5y
Car: 93 240sx
Ok so my car has failed inspection and I need new motor mounts. Since I'm going to replace them I'm trying to figure out which ones to get, I'm leaning towards something stiffer than stock but I don't think I want the solid mounts just yet.
The car is my second car and eventually will be a project/track car.
Anyone have experience with the following and could give me some insight into how they perform/hold up over the long term?
Home made mounts a-la-AZHitmanCusco/ProjectSilvia MountsMegan Racing MountsNismo Mounts
Thanks,
Eric
el5y
Car: 93 240sx
anyone?
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Nismo mount are great. They are no too stiff and take alot of slop out of the drivetrain. Only prob is that they dont sag as much as the stock ones so your motor will sit about a 1/4 inch higher, so it might hit your strut bar. I have a DCsports strut bar and it doesn't hit.
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
hockey puck mounts...cheep and lower you engine for better center of gravity..20 bucks max to make..good luck
el5y
Car: 93 240sx
I saw the hockey puck mod but I'm not quite sure I want to go that route. I think I'd rather have something that has some compression to it.
el5y
Car: 93 240sx
anyone else?
liquid_cool
its been used for years by engine swapp pro's ...510 guys love em...gives that little extra clearence for the strut bar too..but hay..its just a sugestion.
el5y
Car: 93 240sx
I understand where you're coming from liquid_cool but I'm also not looking to build something that stiff or strong.
If it comes to the point where I'll be swapping the engine then I'll look at something like that right now I just want to pass inspection and still be able to drive the car everyday without getting my teeth rattled to hell
Eric
el5y
Car: 93 240sx
come on guys, I know more of you must have changed your motor mounts
Valett85
Car: nissan 240sx se (93 240sx se and 95 240 sx se)
I'm using megan and they work fine. Very stiff and they make your car vibrate a lot. I actually like the vibration and they make your car sound better on the inside. No change outside of course, it's just that you can hear the vibrations of the car. They make it way more fun to drive.
bruinbear714
Nismo motor mounts are best compromise between stiffness and comfortability.
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
I'm running Nismo mounts on my s14, they're pretty good..
el5y
Car: 93 240sx
Anyone have experience with stock mounts filled in with flexane or window weld?
liquid_cool
filled is worthless..you might as well buy stiff solid mounts..it cost more to buy the crap to fill then it does to make pucks..lol..just get nismo man if ya dont like stifs.
el5y
Car: 93 240sx
liquid_cool wrote:filled is worthless..you might as well buy stiff solid mounts..it cost more to buy the crap to fill then it does to make pucks..lol..just get nismo man if ya dont like stifs.
have you actually tried filling the stock mounts?
I'm looking for something thats stronger (read: won't split apart) than stock, but still supple that I'm not rattling the hell out of my brain while driving it.
Modified by el5y at 9:15 AM 8/7/2009
el5y
Car: 93 240sx
Anyone know if the azhitman mounts will pass inspection?
Inspection?
They actually inspect your motor mounts?
Cripes. Half the crap I saw driving in VA looked like they had a chunk of 2x4 for motor mounts.
Who knows... ask someone at the inspection station.
Sounds like idiocy to me. You can have a fender falling off from rust, but you'd better have good motor mounts!
el5y
Car: 93 240sx
Unfortunately yes...at least the station I went to. I likely won't take it back there but while I'm working on the car I might as well replace some stuff under there you know? besides, after running on 3 cyl for a year I'm sure my mounts are beat to crap.
My Actual list of broken items is as follows:
both motor mounts splitPassenger side bellows boot split, possible PS rack leakBoth front radial arm bushings splitDrivers side tie rod is loose
All of these things seem like it wouldn't be too bad to fix but I don't know for sure as I've never actually done it. I'd say a weekend of working on the car I would be able to fix it all but its just finding a free weekend to do it.
Eric
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
I have megan mounts on mine. They didn't make that big of a difference other then raise the motor height a bit. I had them and front tension rods done at the same time so it quit knocking every time I stopped real fast.
