ska69 wrote:Hi everybody,
I'd like to upgrade to 450cc dsm injectors, and wondering which MAF should I use:
maxima n60
240sx ka24e
300zx n62
btw, I do have the stock ca18det MAF, and will be happy to use it.
Any help appreciated.
Cheers,
- Tim
You should go with the smallest one that services your needs.
The N62 being good to about 550whp would be an overkill, I think.
The N60 has some kind of a weird voltage mapping, idle voltage is much higher than the others, so you'd lose sensitivity. I've come across numerous threads, where people were having mysterious tuning problems with it. I'd try to exhaust other solutions before using this one.
KA24E MAF is not really big, I doubt it can measure more air than the CA MAF (KA 145hp vs CA 169hp stock), and it won't be enough for the power 450cc injectors would be able to give you. Plus it's that stupid old design, with a separate narrow air channel for the sensor element, jut like the CA. Get one of the newer designs, with the sensor element in the middle.
What I'd go (and will go) with, before switching to a MAP/IAT, is the A32 Maxima MAF, the E60/E61 (pink label). It's the same as the RB25's MAF, should be enough to 300-350 whp. Patrols from about the same model years have this, too, both diesel and gasoline, I think.
The upside with these is, these were sold in Europe. If Kazakhstan got the same vehicles as Europe, you could dig these up or ask for these in junkyards. May be easier to find, than 300ZX MAFs, of KA (US-only) MAFs, and may be cheaper as well.
