which lowering spring
thekawaii
Car: box with 4 wheels
which lowering spring will drop my s13 about 1 to 1.5 inch and not blow up my stock shocks?
i need it temporary until i save up enough money for megan coilovers.
chrislis
Car: 1998 240sx sE!
check into some teins and some eibachs. i know eibach has some that'll do like 1.4 or something similar. i was going to buy em back in CT.
240sxjeff
Car: nissan 240sx zenki version
Just save up your money until you get the coiovers, there is no sense in doing the work twice. And if you just want to ignore my opinion and get springs anyway, I'm taking an extremely wild guess here, but the little flashing red button that says search in the upper right hand corner of your screen probally has your answer
chrislis
Car: 1998 240sx sE!
they have some uber JDM lowering coilovers on ebay for 70 bucks with shipping. try em out and let us know how they work. also, let us know if your car hits the ground when they snap. it'd be pretty ultimate.
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Behold! The Wheel/Tire/Suspension forum has stickied FAQ's for you to use!
zerothread?id=11638 (scroll down to find springs)
My word of advice: stay away from sportlines and you'll be fine--you don't need coilovers on a daily driver, contrary to popular belief.
thekawaii
is sportline that bad? will the car hit the ground? ok. NO sportline!
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
I personally like the drop and stance tien s- techs give. Check them out!
skydragoness
thekawaii wrote:is sportline that bad? will the car hit the ground? ok. NO sportline!
Yes, they are bad primarily because they are progressively rated (as in the spring rates change), w/ such a low drop and underdampened shocks like the KYB's, you'll have blown shocks in a year or so. Not worth it. There are TONS of better springs out there, Tein, RS*R, Suspension Techniques, and H&R namely. Believe me, I used to have them, then i researched and switched.
GhostDriver
Car: 1991 Nissan 240SX RMS13
If I had to go with springs again, I'd look into H&R or RS*R race springs. S-Techs are becoming too soft and I have my shocks on stiffest rebound.Also, you might want a linear spring for predictabilitiy as opposed to progressive springs that become stiffer.
thekawaii
heystock spring is rated 2kgbut some of springs like Megan is like 7kgit's 3.5 times stiffer right? then it will blow up the shock right?so, to not blow up my stock shocks, i should get spring that closer to stock rate.
am i going correct way?
edit: i was going to get tein cuz it's cheapest i could find. Spring is just for temporary like 4~5 months, i wish i could find used one.
GhostDriver
If they're going to be temporary I wouldn't even bother buying and installing springs...just a waste of your time and money.
nismofly
Car: 89 Nissan 240SX Hatch
your not even buying shocks, just the springs?
then yes, it isnt worth it
grimple1
Car: 95 240sx Zenki
Tokico HPs and Sportlines seem to be a popular choice.... aside from the numerous coilovers.
Juujai
kyb agx + eibach pro is popular
a cheaper less aggressive option is gr-2 + tein s-techs.
i don't like tokico period... lots of people i know blew em using tokico springs also in a very short period of time just daily driving also...
koni yellows are always ownage but pretty $$.
these shock spring setups won't really allow you to drop a significant amount. stock 240 wheel gap is more than lots of suvs... just like stock 240s wheel fitment is ....
for me it's either keep it stock or go kts or something.
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Will getting the Tein S-techs mess with the camber at all? i'm sick of my car looking like a 4X4 truck.. but I don't want it to look like some mexican rice moible with funky camber
drifter_for_life06
Car: Daily: '16 WRX
Toys: '92 RPS13 400whp
Exocet
hopupracing.com has a shock/srping Tokico kit for liek $400
GhostDriver
Kenrik wrote:Will getting the Tein S-techs mess with the camber at all?
Yes, you'll net some negative camber up front and a bit in the rear. If you want to autox then its a blessing in disguise but you might want to get an alignment to make sure everything is going straight.
thekawaii
nice. but tein s-tech spring rate is just 3kg. stock is like 2kg. hm.....
