MesaZ wrote:Check out the Beltronics STi as well, great product!
Its a good detector but unless you live in an area where detectors are illegal (Virginia, DC and parts of Canada) there are much better detectors for the same money you'd be spending for the STi Driver.
The Escort 9500ix is more sensitive and comes programmed with the locations of thousands of redlight/speed cameras and can also be updated through a USB port. Beltronics has recently released a similar detector in the GX-65. Both models use GPS for the camera monitoring systme and this gives the added bonus of giving the user the ability to lock out areas that always generate false alerts (say a shopping mall or gas station with automatic door openers). Prices for either of these top of the line detectors (or the STi Driver) is in the $500 neighborhood.
If you're looking at buying both a radar detector and a laser jammer its time to look at the Escort 9500ci. Its a custom installed (CI) detector that is invisible to radar detector detectors like the Beltronics STi Driver, comes programmed with redlight & speedcam locations and can be updated like the 9500ix & the GX-65, has an amplified speaker unit, but also has a trio of laser jamming heads (two front and one rear). Nearly invisible inside the car no one can really tell its there. Its a really slick setup - it also retails for $1600.
Z31toZ32 wrote:Has anyone here bought VEIL and if so, can you share your thoughts on the product??
I don't currently use it but the Guys of LIDAR did some Veil testing in their 2008 Laser Shootout. The results from the headlight shots are pretty impressive. The numbers from front plate shots may look odd, but if you read the test methods you'll notice they didn't coat the front plate with Veil. Scroll down almost to the bottom of the page to check out the numbers.
