MistaZ31turbo »
https://forums.nicoclub.com/mistaz31turbo-u128954.html
Fri Aug 10, 2012 3:34 pm
Ok i got a 95 240sx that had the head gasket blow on my on my way to school. So I dragged it to school then pulled out the motor and transmission together, separated the two, broke the top end down and replaced the head gasket. Threw everything back in the car (this all took me twoo week to do because I did it alone), plugged the wiring harness back up, and attempted to fire it.....motor turns like it had no compression. At this point im pissed at the whole world. So i do a leak down test and compression test and the numbers were pitiful. Cyl 1..20 psi and the rest about 10.
The leak down showed between 90 and 95 percent leak in all cylinders. So my question is this.....since i reused the head bolts could that be why I dont have compression or/and could it be the fact that maybe my piston rings collapsed? Yeah I know i should not have reused the bolts but I figured since this is a stock KA it shouldnt be an issue. So what do you guys think? Will just replacing the head bolts solve my issue?
