+1 Don't forget to poop before hand too!zachattack_5491 wrote:Wear fewer clothes and shave your head when you drive
cause that ain't cheap!!bersh240 wrote:why not just add power?
Not worried about anything, just wondering which would be lighter between the two. I already know it takes hundreds of pounds to make a difference that you can see. Just seeing who knows the answer.martins_240sx wrote:if your so worried about weight look at this
http://en.wikibooks.org/wiki/Nissan_240 ... _Reduction
your "prolly the same weight" answer would have been enough... i didnt mean to upset you. keep in mind this is a public forum where questions are asked. Never seen that question asked before so i asked. And asking if filling your tires with helium will make you float is far from the question i asked.. my question must have not been too "pointless" for you to take the time and answer it. Maybe we need more "whats the difference between black top and red top questions....martins_240sx wrote:the answer to your question is they are prolly the same weight. theses cars were manufactured nearly 20 years ago. the weight differences if you look on the manufacturing line has nearly 80lb window between car to car. this is pointless. you might as well have asked if the cars with a hud are heavier or if i fill my tires with hellium will i float.
I do appreciate the answers from you and everyone else. im not taking the answers in any negative way at all. If it was a pointless question i do apologize because i also hate seeing the same question over and over again. The reason why i asked was because once i removed my sunroof, i was surprised at how heavy it was. I know that base models are lighter because they have no sun roof but i was told a base model is still lighter due to more reinforcement supports found on the SE. And i have seen the support reinforcement on base models that SE's do not have so i was curious if there is a weight difference whether it be large or small. Im not looking to be super light, im running full interior and xxr 18x10.5's so weight is not a issue to me.martins_240sx wrote:I gave you a great reference. but like darens13 said, and me. pointless amount of weight. from my understanding its usaully about 100lbs to eliminate one tenth a second on a 1/4 mile. this difference in weight would be unmeasureable in reference to time. I do apologize for taking this so retarded. the fact of this matter is how you put it " keep in mind this is a public forum where questions are asked" you can also get a publicly answered question that may not be the one you want. and the differences between those engines would be a great question to ask. considering it actually has pertinent differences. thats why its been asked so many times. but like i said I apologize for flaming you.
I used to be all preoccupied with being lightweight too. But the Z32 guys persuaded me to this line of thinking too. Reduce weight sensibly, but you don't need to go crazy over it. At least for a car that sees mostly street duty.bersh240 wrote:why not just add power?
28HP is not very fast.simmode1 wrote:1hp for every 100lbs of weight is usually enough to feel pretty quick by most ppl's standards.
But popped sun roof is good style.pj wrote: go for one with no sunroof in the first place. and the weight diff between the 2 is small enough to not even care.
replacing your power windows with manual windows? lol might as well take out a few floor mats while your at it.....NismoRTuneS13 wrote:I will be replacing my power windows with manual ones also. I know the base model has a support that run down the center of the roof which the se does not have.
