Nathan wrote:Actually, a stock block SR allready made >500hp, and one is claimed to have done over 600, both in Florida. This is why I built the block of my KA
Stock, it can't keep up...but I think built it can own all!
Several stock block SRs have made 500+ hp, and the one in Tampa has hit 600HP, SAE corrected, don't know what type of headwork, but stock bottom end. That's the highest I have heard about SR.
KA, last I heard was 350HP @ 15psi, motor was all stock, that d240t dude or something. Someone made 504rwhp, but I think it was internally built, it's talked bout in the thread 'strength of ka block' or something like that. I could totally be off, please someone correct me if I am.
CA, damn...beats the hell out of me...I haven't heard anything, but I'm sure those CA boys would be able to crank out some good numbers.
The problem with all these uber numbers is that there's no guarantee you'll hit it the same. Also there's the issue of running pump gas as opposed to high octane gas. There's the issue of whether or not the stock bottom end was refreshed. There's the issue of whether or not the head has been done up. And a million others...
P.S. When someone says stock bottom end, I'm assuming everything below the head, but does that include pistons? I mean can someone clarify what stock bottom end, stock block, stock internals...i.e. listing out what part is consider part of what? I mean, is headwork not considered internals, even if u are messing with the valves?
