Which is a better turbo?
sms240sx
I'm looking to get a bigger turbo. I need to know what power, lag, trim, and response is for these turbos:
T3/T04ETO4ETO4ST3/60-1
Here is the setup on my car:
'91 240sx Hatch w/ no options.S13 Sr20detRebuilt Stock T25 Turbo w/ 12psi30x6x2 FMIC2.25" HT Hot Pipe2.50" I/C PipingWalbro 255 LPH Fuel PumpDenso 550cc Injectors3" HT Downpipe3" Custom SS ExhaustZ32 MAFSBlitz Super Sound BOVNX N-tercooler ChillerApexi Super AFC llSARD Tuned ECUApexi Air FilterBleed Valve Boost ControllerZ32 Fuel Filter
I'm looking to pull off low 12's
candela
Just to let you know ANY of those turbo combo's be VERY VERY different as each one has different trims, A/R's and housings...
Ex: you can have a t3/to4e, t3/to4s or a 60-1 in a to4e with a standard turbine wheel in a .48 or a .63 or a .82 housing...etc etc
I woudl say that you need to be more specific with your goals, expectations and wants from a turbo. I think the Big T28 is a very nice bolt on upgrade to stock SR mani's and is capable of low-mid 12's if supported correctly and tuned/driven right.
f150intally
If you are only looking for Low 12s then don't waste your money on a new manifold and custom downpipe etc. You will need approximately 300-325whp or so to reach low 12s. As long as you have appropriate traction. You could go with a FP Big 28 but a better choice may be the Garrett GT25R, .64AR. You could easily make 300-325 but have the ability to make more if you ever want to.
Gosh, actually for 300-325 there is a ton of turbos out there such as the s15 turbo or the GTI-R turbo, etc. FP28. You really don't need a hybrid turbo to make that power.
-Jay
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
check out the post "Forced Performance".
sms240sx
Well then which turbo would work best with my setup? I'm tired of messing with stock manifold and I'm looking at turbos from cheapturbos.com. I'm not spending $1200.00 for a turbo.
superior-motorsports.com
candela
if you dont want stock manifopld then get a t3/to4E 50 trim with a stage 3 turbine wheel in a .48 or .63 turbin housing with a top/bottom 9harder) mounts manifold. Support it properly and tun eit and make 300+ whp
loudbay
Car: duh
get a cheap tubular manifold and a hks gt25r.... that's what i've got, and i'm very happy..... oh and i kept my piping, and downpipe.... as for the cheap manifold, i went to the old-welder here in town and had him do some support welds and fixed a couple of weak looking spots before i ever installed it....
loudbay
Car: duh
i've got the ar .50 (made for mid range boost levels) and i'm glad i didn't get the .64 my buddy has it and it's a little more laggy
