Which injectors will fit?(if needed)
Tai Mai Shu
I'm doing an SR build up, and was wondering if I will need upgraded injectors for the engine at 14psi (1 bar) I know that is maxed out on the turbo, but what about the injectors?
and if they do need injectors, which is the cheapest best way to go about doing it? I found supra injectors cheap, and I think I remeber in some post that they will work, thanks for the help.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
i would just shell out 500 bucks for 550cc injectors from http://www.Jspec.com regardless. last time i checked running lean isnt so good....
KRPSICHI3
Car: I love to race, or anything else pertaining to cars particularly Japanese sports cars.
With a stock Turbo at 1 bar of boost will bring Injector duty up to 100 %. I upgraded to S15 Injectors 480 cc Also Injector duty 100 %. Use 550 cc. However I am running 550cc with a Power FC and it is still running rich. Have not seen 550cc injectors run right on a stock computer.
