StricNyne »
https://forums.nicoclub.com/stricnyne-u10935.html
Fri Jan 28, 2011 1:30 pm
its a combination of rail and intake manifold, the rb20 uses top feed high impedence, if u can get those from DW they are drop in and just need a tune, if u go with gtr top feed low impedencce u need to wire in a resistor which is not that bad but its still something that needs to be done and is not too hard but its not simple either, your other and final choice would be to use side feed inj which is completely a** backwards and makes no sense, more than likely the rail your using has like 10.5 which is oem size, for simplicity i would get inj that size, and if u want to use an fittings get a top feed rail but make sure its 10.5 DO NOT buy those dual rails they are peices of s***
