are you aware of what your getting into?VigVoodoo wrote:I am building a 650-750BHP SR20DET setup. What I need to know is where I would be able to find 1200+cc injectors that will fit an HKS fuelrail? Also does anyone know which piston/rod combo (thinking of CP/Eagle) would be the most reliable for a setup of this HP rating? Thanks!!!
check on a site that sells RX7 performance parts or search ebay.VigVoodoo wrote:I think I am. If not then I have many friends in the high HP domestics hobby that will help me out a bit. Thing is they do not know much about imports. Anyways, have any info on 1200cc JDM topfeed injectors (not Bosch/MSD type)? Thanks!!!
making big power and getting that power to the ground are very different things. plus, unless you do a lot of work, your turbo lag will suck.VigVoodoo wrote:Why?
i will second the GT3582R if you insist on 600HPVigVoodoo wrote:Basically the goal I am trying to reach is a low 10 second car. The car is a fully stripped S13. I will not be using any interior parts, everything is gone. All unused brackets have been shaved off, windows are gone, all electrical is gone. No dash, no A/C, no power steering. Only things will be a STACK dash display, racing seat, rollcage, harness, and the obvious stuff like shifter, steering, etc. I also will be using a 8 gallon fuel cell, all new lines (fuel and hydraulic). Everything that will not be used for racing is gone. So what do you all recommend?
My buddy is hitting 9's and he has just under 600 hp. He was hitting 10's with under 500 hp. Of course he dropped 700 lbs from his S14, but none the less. BTW, his blacktop S13 motor is internally stock. Even the headgasket. All he did was re-torque the head bolts and he's had that setup for 2 years now. Just some food for thought.VigVoodoo wrote:Will the Meziere electric water pump kit work for the RWD SR20DET? By the way, I still haven't found 1200cc top feed injectors for the HKS fuelrail. Should I go with the JWT fuelrail and MSD 998cc injectors? So then, what is the least horsepower I will need for low 10's? Thanks!!!
RC makes 1000cc injectors too and jgycustoms has a fuel rail you can order with bigger or smaller injector bosses. You can also just make your own fuel rail and get whatever injectors you want. If you're running an E8 you can always consider secondary injectors.VigVoodoo wrote:Will the Meziere electric water pump kit work for the RWD SR20DET? By the way, I still haven't found 1200cc top feed injectors for the HKS fuelrail. Should I go with the JWT fuelrail and MSD 998cc injectors? So then, what is the least horsepower I will need for low 10's? Thanks!!!
good idea. 550 sounds about where you want to be anyway.VigVoodoo wrote:After all the suggestions on here I'm really rethinking my 650-750bhp goal.
Yeah, there's been a few...and there was no SR20det 18 years ago.Nicksemianiw wrote:No SR has hit 750BHP to my knowlage, and the true japanese tuners have been working on these cars for over 18 years........
