Turbo_Nismo_EC »
https://forums.nicoclub.com/turbo-nismo-ec-u600.html
Fri Mar 07, 2003 1:07 pm
I picked up a set of higher flow injectors from VENOM. Of course I don't think that the ones I got for my 95 KA24E will fit yours(side feed), but they sent me top-feed ones by accident at first, so I think atleast they have them. I decided to go this route because I wanted brand new ones and these particular ones flow 10% better than the stock ones so I can use my stock ECU but are wound different so I can safely run an FMU set-up on them. THey were just under 300 for the set and they can make custom sizes also if you need. Also, another reason I got them is because I wanted brand NEW ones and they were about 150 bucks cheaper than OEM replacements.
But then again they are a little more expensive than the route you have said also. I just thought I would add this about the VENOM ones.
