which hydrolic lifters to use ?
beans33
Car: 1993 ca18det 240sx
I have 2 ca heads, so i have 32 hydrolic lifters. one set of 16 are kinda easy to squeeze. The other set are harder. which should i use. Im assuming to use the harder ones. But just makeing sure. thanks
sideways danny
Car: s13, CA18DET
I'd have them stripped and cleaned out first myself, but if you don't do this, use the ones that can be compressed easily (a good indication they are not sticky)
biosehnsucht
I cleaned mine by soaking them in acetone IIRC (might have been some other crazy chemical), then kerosene, then 5w-20 or something and then the oil weight I was going to run when I put them back in .. if I remember correctly.
each step it lost a little more crud from inside just coming out on its own
soaked them overnight each step pretty much..
beans33
at the end of each step were they easier to squeeze ?
biosehnsucht
yeah
also be sure not to let anything tdrain when moving them around as it just means all the air has to be forced out again when the engine starts, try to keep from dumping the oil out when you put them in.. not that its likely to make a huge difference i guess
float_6969
The easier they are to compress, the better.
sideways danny
Car: s13, CA18DET
make no difference in my experience
biosehnsucht wrote:yeah
