Which headgasket to buy: GReddy or Tomei
f s t caz
Car: VG30ET D21 Extended Cab Pickup
The Tomei head gasket is $224 shipped, the Greddy is $239 shipped from SPL. Does one have an advantage over the other, or has one proven itself more than the other? Thank you for your input.
themadscientist
Tomei super stopper is a superior design to the bead type Greddy. It has a ring around each cylinder that is crushed when installed as opposed to the bead type which is just a stack of wavy sheets. Tomei makes a bead type as well so be sure you know which type it is
BoroBoroS13
Car: S13, RS13, and S14
I would go with the Tomei just cause I feel they produce better products.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
im cheap and the tomei HG is over 1 case of beer cheaper than the greddy unit. it doesnt take rocket science to figure out the better deal.
- tim
float_6969
Tomei. Thats probabally whats going on my car if I blow the stock headgasket. I've got a brand new OEM headgasket, so I'm going to try it and see if it holds. If not, no biggie, I pull the head and throw another one on there...
themadscientist
r34 gtr wrote:im cheap and the tomei HG is over 1 case of beer cheaper than the greddy unit. it doesnt take rocket science to figure out the better deal.
- tim
Then it`s likely the bead type. the super grommet tag looks like thisスーパーグロメットI see that CA gaskets have dropped in price though so maybe it is
float_6969
I've been shopping recently, and the SuperGrommet from Tomei is more expensive than the Beaded from Greddy everyplace I've seen. Do as TMS said and make sure it's the SuperGrommet style and not the Beaded style from Tomei.
niscort
FWIW... tomei bead 16000yen, supergromet 28000yen
themadscientist
I paid Y33000 for mine, I guess they lowered the price to move them. Guess I better stock up while they are still available. I forget the engine went out of production 15 years ago!
f s t caz
themadscientist wrote:I paid Y33000 for mine, I guess they lowered the price to move them. Guess I better stock up while they are still available. I forget the engine went out of production 15 years ago!
tomei actually just raised prices on everything very recently, and the super bead will cost $280 instead of the $224
float_6969
Yea, like I said. I'm gonna run the stocker and see if it holds. Unless I det. on it, I think I'll be fine...
boost_boy
float_6969 wrote:Yea, like I said. I'm gonna run the stocker and see if it holds. Unless I det. on it, I think I'll be fine...
You'll be just fine!
Dee
float_6969
Maybe I'll just get real crazy and see if it will hold 14psi w/9.5:1 compression and a 75shot! LOL, that is the formula for a broken motor, right there!
themadscientist
It took 21lbs to pop my L20ET head gasket, give it a shot.
fraz
Car: rb30det gts4
vh45 g130
I have been using ajusa headgaskets. i think they are made in spain or something. cost bugger all and have not blown one yet. I recommended them to a few friends and i know one guy running 20psi on a det and has had no problems.
I also use the ca18de gaskets on my ca20de and have had no problems so far, even with pretty high compresson
float_6969
Woot, there's hope for me yet!
240DRFT
where did you find those? i went to SPL site and they only sr headgaskets...
f s t caz
240DRFT wrote:where did you find those? i went to SPL site and they only sr headgaskets...
at the top of the page, it says "Looking for CA18 or SR20DE parts? Please call or email for quote." so i emailed kuah and inquired about gaskets.
