Q45tech wrote:All in all a basic 1990 Q [lowest weight Q] with Eibach, 28/20 mm sway bars, and corrected camber with the best tires on the lightest wheels will out handle the rest.
I strongly disagree. Once driven as if you are "a mob-boss on the wildest goose-chase Hollywood cannot image," undoubtfully... the best handling vehicle is a bone-stock 1994 Q45-T (w/HICAS & 15" BBS/Firestone unidirectional tires).
At twice+ the speed of traffic, harsh road surfaces, curves, and maneuvers to avoid traffic all at once is too much for any vehicle, even Corvette. In the Q45-T you still get the chance to signal.
In this car you will realize you were only close to the limit. If only for a slightly higher top-speed this would be the recommended vehicle for the Gumball Rally.
I cannot exaggerate it enough... Street & Freeway handling, this car is one-of-a-kind. A 300ZX TT's handling sucks.
