a pillar is not an option.redtop91 wrote:I'd put the wideband on the steering column. The Oil pressure I'd put on the A pillar.
i don't have that one anymore. i have a 98 kouki now. but the blinkers are off of a silvia. usdm and jdm blinkers are different shapes.xdabsx wrote:my vote is boost and oil pressure i was thinking of getting one of those gauge pods^^^^^ u think u could send me a pic of it in your car i also got the same front bumper as you what kind of turn signal lights are those
phase2 has them. HKS also makes one that you can bore out to fit 2 1/8" gauges.cheapscheisst wrote:does anyone know if somebody makes a 3 gauge insert that goes below the radio for the s14?
AmoebAssassin wrote:Boost and Oil Pressure where you can see them; boost spikes kill motors and lack of oiling is always a problem with the SRs.
Wideband and water temp above the radio. WTF are you using a voltage gauge for! Replace it with an oil temp, thats far more critical than voltage, rofl.
Ebay has one that angles all the gauges towards you, I'm thinking about molding it in with fiberglass to make it look cleaner. 52mm gauges fit that onecheapscheisst wrote:does anyone know if somebody makes a 3 gauge insert that goes below the radio for the s14?
