Which gauge for monitoring engine?
uglypedro
Car: '04 Infiniti G35 coupe
Installing a oil pressure/temp single gauge. The pod has space for 2 gauges. What other gauge is good to have for an NA engine. Water temp (already present in g35) or Volts or ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If you're "grandpa" then I'd say a voltmeter is most useful. If you're a "spirited" driver then oil and/or transmission temperature wouldn't hurt. If you're "Bernie Burnout" then a 2-axis Accelerometer (G-meter) or an Artificial Horizon are basically useless but very cool.
