Which G35s came with an LSD?
adren77
Car: 2004 G35 Laser Red Coupe 6MT
Which G35s came/come with an LSD?
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
2003 didn't. 2004+ did.
To add be more clear:
2003 sedans didn't have an option for VLSD
2004-2006 sedans had a sport package option which came with VLSD
2007 sport sedans have VLSD, base & journey have ABLS
2003-2004 coupes had VSLD if it was a Performance Wheel and Tire package option, which meant 18" wheels auto or manual.
2005-2007 coupes only those with the Sport Suspension Package had VSLD
*The 18" wheel option for 05/06 is only that, wheels and tiresVLSD became part of the Sport Tuned Suspension package for 05/06*
To clearify what "sport package" on the sedans:
Breakdown of oem VLSD fitment G35 sedans, all production
03 AT with or without sport suspension: NO03 MT: NO (has sport suspension standard of course)
04 AT: with or without sport suspension: NO04 MT: Yes
05/06 AT with sport suspension: Yes05/06 AT without sport suspension: No05/06 MT: Yes
joe603
Car: 2014 Durango R/T
itgogitrev
Car: 1996 GTI VR6T, 1981 DeLorean
I'm glad this was brought up, I was about to post the same question. There's a G-sedan that I want to look at and it mentioned 'sport package', but I wasn't sure if that meant LSD or not.
It'll be worth the 120 mile trip now to check it out.
W661335PF
Car: 2004 G35 sport sedan-- Mod money goes to 401K
I
adren77 wrote:Which G35s came/come with an LSD?
I didn't know our G's came with LSD, where is it hidden????
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
Is there any way of confirming LSD on a coupe? Other than turning VDC off and trying to do doughnuts?
joe603
Sentientbydesign wrote:Is there any way of confirming LSD on a coupe? Other than turning VDC off and trying to do doughnuts?
Call the dealer with your VIN #...
Sentientbydesign
96 I30 - Sold
Great answer!
RED_DET
Vendor
2011 Infiniti G37x
I'm sure I covered coupes and sedans in my post of which cars have VLSD.
Sentientbydesign
96 I30 - Sold
It was somewhat complicated to figure out.
AND
Any dealer can slap on larger rims. That doesn't make it a sports package or infer that it has VLSD.
adren77
Jack up the rear wheels of your car, and turn one of your rear wheels. If you have open differential, your wheels will spin in opposite direction (make sure you are in Park or 1st gear). With LSD, they will spin in the same direction.
Sentientbydesign
96 I30 - Sold
I haven't bought the car yet, so I need to be able to ID it before purchasing it, taking it home, jacking it up, and trying to figure it out then.
RED_DET
Vendor
2011 Infiniti G37x
I looked at the vin/engine/transaxle code under the hood on the pass side in front of the battery. I have VLSD and the code reads FS6R31 R35. Look on the car and write down the transaxle code. I will try to get one of the others on here that don't have a vlsd to confirm the numbers.
SpeedRacer1
Car: 1990 240SX, G35
You only need to jack up one wheel. If that rear will spins freely its open. If it spins but only under heavy rotating its a vlsd.
Sentientbydesign
96 I30 - Sold
Excellent. I will post something as soon as I can.
RED_DET
Vendor
2011 Infiniti G37x
It appears that if there is a titanium color trim for the console/radio bezel, that is another indicator. Sport Package/Performance Tire & Wheel package came with those color trim interior pieces.
tjmhillz
Car: 2001 Lexus IS300 Turbo
this should be a sticky
Tampa G35 Sedan 6MT
Car: 2006 Infiniti G35 Sedan 6MT Black w/ Premium & Areo Pkg
1989 Jeep Cherokee 4X4 Lifted and Old School!
But all MT's have the VLSD. Except if it is an 03 and doesn't have the sport package
DJ
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
I have a 2003 6MT Brembo Coupe that had the stock 18inch wheels when I bought it.
LSD>> ???
Tampa G35 Sedan 6MT
Kenrik wrote:I have a 2003 6MT Brembo Coupe that had the stock 18inch wheels when I bought it.
LSD>> ???
Yep.... YOU GOT IT!
DJ
Jacko3
Mine is a 2007 Coupe with RAS, VDC, and LSD. Only way I could tell without jacking up the car is that in the rain, at very high take-off or with enough torque, the LSD light on the dash board starts blinking very fast as your tires spin on the wet ground. If you don't see that blink on take off with spinning wheels then you do not have a LSD. The blink is different from the gear shift light that blinks when the car requyires you to shift.
The other interesting technology is the Rear Active Steer (RAS). I have found the use of the VDC useless on curves, with the RAS. The RAs and VDC together makes the need for an after market sway bar not really important. The RAs really works like magic. It holds the rear of the car tightly in place. However, becasue of this, an alignment of the tires every 15,000 miles is a must in order to ensure that your tires are not wearing away on one side than the other, due to the effect of the curves.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Jacko3 wrote:Mine is a 2007 Coupe with RAS, VDC, and LSD. Only way I could tell without jacking up the car is that in the rain, at very high take-off or with enough torque, the LSD light on the dash board starts blinking very fast as your tires spin on the wet ground. If you don't see that blink on take off with spinning wheels then you do not have a LSD. The blink is different from the gear shift light that blinks when the car requyires you to shift.
ALL G35s have the SLIP Light..
Alignment... effect of curves?You're talking about camber wear right? Huh? that has nothing to do with RAS.
And about not needing a after-market sway I guess you don't do much REALLY hard driving.
Jacko3
Kenrik:
You are right, maybe I don't do too much driving afterall. I really don't know how much harder to push the car. I have gone through curves at 90 -100 miles per hour with the VDC off, and the RAS has partly made this possible. Because the RAS makes the rear wheels turn at speeds over 50 MPH, the rear tires especially will wear out unevenly for that reason. These are just my observations, as i have not observed the same phenomenon on my second dino car that has little to no technology in it. I maybe wrong, but how do i dismiss what i have seen with my eyes?
telcoman
W661335PF wrote:I
Only the old farhts get it
Tampa G35 Sedan 6MT
LOL
QX1
Car: INFINITI G35 2006 6MT
RED_DET wrote:I looked at the vin/engine/transaxle code under the hood on the pass side in front of the battery. I have VLSD and the code reads FS6R31 R35. Look on the car and write down the transaxle code. I will try to get one of the others on here that don't have a vlsd to confirm the numbers.
Does it mean that FS6R31A RC35. is not viscous limited slip. Mine is with A. what this A means?
Ron C
Car: 2004 g35
Do a short burn out , if one tire mark you dont have lsd , less work , more fun
RED_DET
Vendor
2011 Infiniti G37x
Jesus, this thread is older than you car!!
