Which fuse controls the trunk interior light?
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
fourdrinie
Car: 2019 Q50
I am trying to connect an extra light to the trunk interior light which goes on when the trunk opens.
I think I blew the fuse.
I'm having trouble finding a blown fuse in the fuse box by the driver's left foot.
Can someone definitely tell by a wiring diagram which is the correct fuse?
Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's no separate fuse. Power comes from the Room Lamp supply in the BCM and ground comes from an individual control wire at the BCM. If the former blew then most of your interior lights will be out, if the latter blew then only the trunk lamp will be out. In either case the only fix is to replace the BCM.
Return to “Infiniti Q50 / Q60 Forum”
